What ads network you got to work and use?
Ici se font toutes les annonces et déclaration de l'équipe de GTA Légende sur des décisions, nouveautés, etc...
Messagede JacobOlivia le 25 Oct 2017, 09:24
Hi,
It's easy to set up and you will be covered with whatever you need. I see that LeadBolt is very bad because it simply can't compete with the others, Playheaven and are known to be bad so I didn't even set them up . Admob and Facebook for banner ads is a must. I have heard that Heyzap is very good for Android (and up to now I can confirm this). So if you go Mediation you have this set up automatically. Chartboost seems to be one of the best options for iOS.
I didn't find the right solution from the internet.
References: https://www.buildbox.com/forum/index.ph ... -use.3132/
Promotional Video
JacobOlivia
Retourner vers Annonces du network
